Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Problem with contact/target view. › Reply To: Problem with contact/target view.
Sampat Kumar
Hi
Thanks for your patience.
I am not sure if you are working on this issue or not but I am providing a solution that would help others with similar issues.
As I can see in your first image, you have selected multiple sides on the two different bodies that's why there might be a chance that you are not able to see the transparent body.
It's similar to that I have attached in the image below. Please select the contact side properly and let me know if you face any issues.
Best Regards,
Sampat
