Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Additive manufacturing DWELL TIME › Reply To: Additive manufacturing DWELL TIME
I would recommend setting up am AM test case in WB-Mechanical that incorporates dwelltime as prescribed in the Mechanical GUI=>AMProcess Details window and is working successfully. Then refer to the corresponding ds.dat file for the proper execution of all the AM related commands for this standard test. The commands should look something like the following:
Compare this with your customized approach to try to discern what might be missing.
I am not sure what you are doing with "...apdl commands and customized(Hybrid) heat source" and how that is working (or not working) with the execution of 'AMBUILD,time,,,' to incorporate dwelltime, but it might not be possible if some of the other AMBUILD commands are missing and/or out of order.
