Ansys Learning Forum Forums Discuss Simulation LS Dyna LS Dyna MPP double precision Reply To: LS Dyna MPP double precision
Atish Gawale
Hi Reno,
Could you help me which mpp R14.1 version shall I install on Linux system? There are several directories listed below.
For example if I select ifort 190 sse2/, then do I need to install and try run with intelmpi, openmpi and platformmpi? or only mpp d intelmpi should be enough.
Atish
