Ansys Learning Forum Forums Discuss Simulation General Mechanical Is the displacement and rotation Angle of time sequence entered in AQWA? Reply To: Is the displacement and rotation Angle of time sequence entered in AQWA?
Shuangxing Du
Aqwa-Rigid Dynamics co-simulation uses Aqwa to calculate the hydrodynamic force and mooring force, and uses Rigid Dynamics to calculate the motions and joint forces.  Aqwa cannot directly import the displacement, then calculate the joint forces.
