Ansys Learning Forum Forums Discuss Simulation General Mechanical AQWA_linear damper problem Reply To: AQWA_linear damper problem
Shuangxing Du
Fender's damping force is linear to the retative velocity if the dender's stiffness is defined as linear (see Aqwa Theory manual, equation 9-89). As shown below you could define a pair of fenders in the opposite directions normal to the structure's contacting surface.
