Ansys Learning Forum Forums Discuss Simulation Fluids Non-Premixed Combustion PDF generation with 4th-order interpolation Reply To: Non-Premixed Combustion PDF generation with 4th-order interpolation
Vijay Narayan
Hi Mana,
Are you shifting the case from FGM partially premixed to Non premixed model ? Based on my discussion internally, this error could pop up when a shift is done from Partially premixed to Non premixed combustion model. The scalars mentioned are some internal variables which are used and not related to any user specified entry.
Could you set the case afresh in Non premixed model and let me know the outcome.
