Ansys Learning Forum Forums Discuss Simulation General Mechanical Force Convergence Issue in Solder Joint Reliability Simulations Reply To: Force Convergence Issue in Solder Joint Reliability Simulations
Harshil Goyal
Just so you understand correctly, Figure 4 above is after I evaluate results.
I am adding another figure below that shows before evaluation both outside window and inside the mechanical when the results are reset. Outside everything is shown with green tick but inside the solution shows yellow flash sign. The reset automaically delete the total deformation evaluation and solution shows yellow flash sign.
When i add Total Deformation option and evaluate (which I am only able to do from outside window as inside it shows solve option only), You can see the yellow flash sign remains same inside mechanical after evaluation even though the total deformation results are produced (evaluated results shown in Figure 4) with the error at the end (outside mechanical in figure 3). The state of evaluated results are not converting into green tick.
