Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Drop test on FRP wrapped beam › Reply To: Drop test on FRP wrapped beam
Reno Genest
Hello Prasad,
Finally, for the "The demanded solver was not found in the specified path." error, it seems your Ansys LS-DYNA installation did not complete properly and you don't have the LS-DYNA solvers in the following Ansys installation path:
C:\Program Files\ANSYS Inc\v242\ansys\bin\winx64
You should see the following solvers in the above path:
If not, reinstall Ansys.
Which version of Ansys are you using? There is one version where the LS-DYNA solvers did not install properly and there is a service pack on the Ansys Customer Portal to solve this:
support.ansys.com
Let me know how it goes.
Reno.
