Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Drop test on FRP wrapped beam › Reply To: Drop test on FRP wrapped beam
Reno Genest
Hello Prasad,
Material model CONC-35MPA from Engineering Data is not supported by LS-DYNA. Please use a different material model with supported material properties. In the LS-DYNA system, click on "Engineering Data" branch:
And then click on "Filter Engineering Data":
This way, you will only see the material properties supported by LS-DYNA in the toolbox. Build your material using these material properties and it will work.
Reno.
