Ansys Learning Forum › Forums › Discuss Simulation › Electronics › radial and tangential flux density › Reply To: radial and tangential flux density
HDLI
Hello Ebenezer,
       You could build two new expressions in field calculator to get Br and Bt. In the field caculator, you can do
        Input > Quantity > B
        Vector > XForm > ToCylindrical
        Vector > Scal? > ScalarX, to get Br
        We have Scl : ScalarX(ToCylindrical(,offset<0mm, 0mm, 0mm>)), you can click "Add" button to add it into "Named Expressions" for Br.
        As same as that we do, select ScalarY for Bt. After that, you can plot or get results for Br and Bt in field results.
HDL
