Ansys Learning Forum Forums Discuss Simulation Fluids hydrogen dual fuel Reply To: hydrogen dual fuel
jcooper
Hi Mahmoud:
Some liquid materials may be unavailable for IC engine model. The fastest way to do this is just to edit one of the particle materials that appear in your dropdown and give it the properties of liquid h2.
 Or you may also be able to add the h2-liquid material using the Fluent Database.
To do this, go to Materials and click on Create/Edit
Select Fluent Database:
Change Material Type to droplet-particle:
Copy hydrogen-liquid:
This will add it to your Droplet Particle Materials:
And you should then be able to change to this material in the injection properties.
I hope this helps.
Best Regards,
Judy
