Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Simulation of transient heat using pulsed laser power › Reply To: Simulation of transient heat using pulsed laser power
Guilin Sun
The error "application terminated with the exist string: handup (signal 1) " is from MPI. You can try another mpi if it still fails after restarting the computer. You may also try to install the latest version.
