Ansys Learning Forum Forums Installation and Licensing Ansys Free Student Software Ansys in read only mode because “system clock was set back” Reply To: Ansys in read only mode because “system clock was set back”
George Karnos
Please see the following post at the end for a suggestion:
You can also search the forum for: System clock has been set back.
License error : NO SUITABLE FEATURE FOUND (ansys.com)
"the key error message is "System clock has been set back.". You should not change OS system clock or date.
Please refer to https://www.geoslope.support/kb/article/97-error-88-309-geostudio-system-clock-has-been-set-back/ . Hope it could work. Or reimage the OS and reinstall
