Ansys Learning Forum › Forums › Discuss Simulation › Fluids › error compiling UDF with personal header file › Reply To: error compiling UDF with personal header file
Luca B.
Hi, it is not simple to provide an answer without seeing the files. There could be probably an error in the source files.
Do you compile them with the same compiler version?
I invite you to visit the following page with more information about the commands 5.3. Compile a UDF Using the TUI (ansys.com)
