Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Submission scripts to run FSI simulation in HPC › Reply To: Submission scripts to run FSI simulation in HPC
Rahul
Hello Swapnil,
I would recommend you to go through following tutorial and user guide:
Solving Co-Simulations from the Command Line (ansys.com)
Using Parallel Processing Capabilities (ansys.com)
System Coupling provides you with the ability to execute a coupled analysis using High-Performance Computing (HPC) resources in parallel. You can run the analysis on a single machine or distributed on two or more machines. Distributed runs are executed directly or indirectly with a queuing system, with Linux support for LSF, PBS Pro, UGE, and SLURM.
