Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Question for RMxpert.. › Reply To: Question for RMxpert..
Navya Chode
Hi min el,
  1. In the winding window for winding type select "Editor". Then Goto Machine>winding>Edit layout
    Then on the popup window, you can customize the winding configuration.
  2. Winding information can be input on the winding window. 8 is the number of strands and calculate the conductors per slot according to the number of turns. you can choose the wire diameter also which is the diameter of each strand.
  3. Not exactly on the outer rotor, but you can refer to the inbuilt examples that come with the installation (File>Open examples>RMxprt).
    Also, look at the below path
    Navya
