Ansys Learning Forum Forums Discuss Simulation General Mechanical 242 Elements – compressible fluid Reply To: 242 Elements – compressible fluid
Erik Kostson
Hi
See the help manual for hsfld242 – hdsp which is basically internal pressure (D command) is explained,
 and so is IC (see IC command for more info – it often needs large deflections to ON to work in static analysis).
Also this post explains the use of hsfld242: https://simutechgroup.com/contained-fluid-in-mechanical-fea-model-working-with-hsfld242-elements/
Erik
