Ansys Learning Forum Forums Discuss Simulation Electronics A possible bug was found in using of boolean subtract function Reply To: A possible bug was found in using of boolean subtract function
scm17
Hi Praneeth, thank you for your reply~
Can you show the details of "Rectangle2" in your screenshot?If our modeling methods were exactly the same, it would be very confusing indeed.
Or will it be a problem with irrational values of points? Consider that the model is built using parameters, and there are irrational coefficients in the formula. I'm not sure if there is a problem with the software when retaining a finite number of decimal places.
"Unite" boolean operation would work if I untick "Attach to original object" when I duplicate an object, but when I have to do parametric modeling, I should tick "Attach to original object". "Unite" boolean operation would not work when I choose a single duplicated object.
Best regards,
Changming Song.
