Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › The problem of Maxwell’s solution range › Reply To: The problem of Maxwell’s solution range
HDLI
Hello Jingxuan,
     Not really, recommended model size is less than lambda/10 (lambda = c/Freq, c is light speed).  If larger than it, please consider to use Q3D or HFSS. Thanks.
HDLI
