Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Coupling Thermal Expansion to the Heat Transfer Solution › Reply To: Coupling Thermal Expansion to the Heat Transfer Solution
Rahul
Please refer to the system coupling users guide Participant Variables and Quantity Types Supported by System Coupling (ansys.com).and Mechanical user guide Variables Available for System Coupling (ansys.com).
I recommend going over this tutorial in the Ansys documentation that shows a 2-way FSI simulation with Fluent and Mechanical. https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/sysc_tut/sysc_tut_reedvalve_fluent.html
 If the structural model is simple, you can use Intrinsic FSI which is an FEA solver built into Fluent. The tutorial is here: Chapter 25: Modeling Two-Way Fluid-Structure Interaction (FSI) Within Fluent (ansys.com)
