Ansys Learning Forum Forums Discuss Simulation General Mechanical How can I export multiple data at once using chart or APDL? Reply To: How can I export multiple data at once using chart or APDL?
Sampat Kumar
Hi
If you want to export the deformation corresponding to the nodal location then you have to turn on the Nodal location option in the export.
Step1: Tool>Options>Export>Include Node Location>Yes
For the APDL code, you have to modify the below code a little bit and try to export.
/forum/forums/topic/export-of-nodal-displacements-from-workbench-to-txt-file/
Best Regards,
Sampat
