Ansys Learning Forum Forums Discuss Simulation General Mechanical Contact thermal behavior Reply To: Contact thermal behavior
Aurojyoti Prusty
 In Ansys Mechanical APDL, you can specify thermal contact conductance using the Contact Properties dialog. The thermal contact conductance (TCC) is a coefficient that defines the conductive heat transfer between two contacting surfaces, and it can be set as a constant value or as a function of temperature, pressure, time, and location using a table. The formula for conductive heat transfer is q = TCC x (Tt - Tc), where q is the heat flux per area, TCC is the thermal contact conductance coefficient, and Tt and Tc are the temperatures of the contact points on the target and contact surfaces, respectively.
Hope this helps,
Thanks
Aurojyoti.
