Ansys Learning Forum Forums Discuss Simulation Electronics A possible bug was found in using of boolean subtract function Reply To: A possible bug was found in using of boolean subtract function
Praneeth
Hi Changming Song,
Please note that you can use "Unite" boolean operations to implement "merge-like" operation in AEDT.
I tried to replicate your model to the extent possible and I did not see any glitch during the subtract operation. I am sharing a screenshot of the same for your reference.
Also, one more interesting point here is - in your model only a fraction of the model after performing the subtraction has issues while the remaining portion looks correct. So, I do not think the issue is with the subtraction operation.
Best regards,
Praneeth.
