Ansys Learning Forum Forums Discuss Simulation Fluids Non-Premixed Combustion PDF generation with 4th-order interpolation Reply To: Non-Premixed Combustion PDF generation with 4th-order interpolation
Vijay Narayan
Hi Mana,
Is the issue only with 4th order interpolation scheme ?.
If you generate the PDF table via GUI (default approach, no activation of 4th order interpolation), using either AGR or the specified entry for PDF table - do you see similar error ?
