Ansys Learning Forum Forums Discuss Simulation General Mechanical Force Convergence Issue in Solder Joint Reliability Simulations Reply To: Force Convergence Issue in Solder Joint Reliability Simulations
Harshil Goyal
I did that. I removed the results and and tried requesting to evaluate the new result for only Total Deformation however It is not showing evaluate results options, but only shows solve and start solving the model. My solution file is still in the the folder. When I click reset results (Figure 1 with red cross results) in the project schematic Window, the red cross with yellow flash sign in front of  results changes into green tick (Figure 2 attached) and after this when I open the workbench to see the solution, it still has yellow flash sign. Now I come back to project schematic and right click on results and click update, it starts evaluating results but at the end shows the error that I  shared above (Figure 3). When I see total deformation results, it shows results but not with green tick but yellow flash sign (Figure 4).
Figure 1
Figure 2
Figure 3
Solution of Total Deformation with Yellow FlashFigure 4  Results Outcome
Below are the attached other pics from solution window:
Force ConvergenceSolution History
