Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Force Convergence Issue in Solder Joint Reliability Simulations › Reply To: Force Convergence Issue in Solder Joint Reliability Simulations
peteroznewman
Open Mechanical and look through the results. One of them has an issue. You can freely delete result requests and make new result requests. This will not harm the solution. Once you have all the results correctly displayed, you can update the Workbench project and save the file with all green checkmarks.
