Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Force Convergence Issue in Solder Joint Reliability Simulations › Reply To: Force Convergence Issue in Solder Joint Reliability Simulations
Hi Peter,
I was able to complete simulations for the model mentioned above, and it has successfully generated a solution. However, the file size is quite large, approximately 285 GB. Upon attempting to evaluate the results using the solution, an error occurred at the end. The error message reads:
”Update failed for the Results component in 6×6 QFN Simulations V2 (Design B). Update of the Results component in 6×6 QFN Simulations V2 (Design B) did not mark container as updated (final state is Modified).”
I am hesitant to discard this solution or rerun the simulations, as it would entail a significant amount of time. Is there a method to resolve this issue and still utilize the current solved solution for results evaluation?
