Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Bonded contact in a non-linear material analysis › Reply To: Bonded contact in a non-linear material analysis
April 9, 2024 at 6:34 pm
Myles is correct, using Shared Topology maintains separate bodies that can each be assigned a unique material. In that way, it is different to using a CAD unite command to merge mulitple bodies into a single body. Shared Topology creates a multibody part.
When using Linear elements, make sure to use at least 4 elements across the thin dimension of any body in the part.
