Ansys Learning Forum Forums Discuss Simulation General Mechanical Moving heat flux issue in ANSYS transient thermal Reply To: Moving heat flux issue in ANSYS transient thermal
dlooman
Yes, there is also the problem of too small a time step with higher order elements (producing temperature undershoot.)  You might consider using linear, lower order, elements to avoid that issue.  I don't know a rule of thumb for setting the time step to capture the correct thermal shock surface temperature.  You could determine it experimentally with a test model.
