Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Bonded contact in a non-linear material analysis › Reply To: Bonded contact in a non-linear material analysis
cristian.pujol
Thanks for you're answer
The problem with shared topology is that i can't use it because i have two materials, the big tube is S355 and the other tubes S690
For S355 I used Yield stress 350 MPa and tangent modolus of 2100MPa
For S690 I used Yield stress 690 MPa and tangent modolus of 4140MPa.
So in this case where we have two materials what would be the procedure for "gluing" the two tubes?
Thanks in advance for the answer
Regards
