Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fluent UDF: An example using PRF_GRSUM macro? › Reply To: Fluent UDF: An example using PRF_GRSUM macro?
Luca B.
The PRF_GRSUM macro in Fluent's User Defined Functions (UDF) is used to compute the global sum of a float or double array across all compute nodes in a parallel computation. Here's an example of how you might use the PRF_GRSUM macro in a UDF:
DEFINE_ON_DEMAND(test)
real x[1]; /* Array of size 1 to hold the sum */
real sum;
int iwork[1]; /* Work array for parallel operation */
/* Initialize the array with the value to sum */
x[0] = 5; /* Your code to set the initial value */
/* Compute the global sum */
PRF_GRSUM(x, 1, iwork);
/* x[0] now contains the sum of the values across all compute nodes */
sum = x[0];
Message0("Total = %f\n",sum);
/* You can now use 'sum' for further calculations or monitoring */
In this example, x is an array that you want to sum across all compute nodes. The PRF_GRSUM macro takes the array x, the number of elements in the array (which is 1 in this case), and a work array iwork as arguments. After the macro is called, x[0] will contain the global sum of the values that were in x on each compute node.
Please note that the PRF_GRSUM macro should be used in a context where it is called only once per compute node, such as within the DEFINE_ADJUST macro, to avoid issues with parallel execution as mentioned in the documentation.
