Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Worksheet not working for Solution combination › Reply To: Worksheet not working for Solution combination
Yidu Di
I met also the same problem. When the Worksheet type is set as Single or Envelope, the worksheet can be schown as normal. Only for Multiple the worksheet does not show up at all, although I clicked on the Worksheet button.
Could anyone give a hint about it?
Thanks!
