Ansys Learning Forum Forums Discuss Simulation 3D Design Rotating Fluid Zone with two materials Reply To: Rotating Fluid Zone with two materials
Devendra Badgujar
Hello Karel,
Multiphase flows modeling is not possible in Ansys Discovery. To simulate two separate materials inside a mixing tank, such as air and oil, you can use Ansys Fluent, which allows for the modeling of multiphase flows. In Fluent, you can define multiple phases and set up the volume fraction of each phase in the domain.
Devendra
