Ansys Learning Forum › Forums › Discuss Simulation › Photonics › CHARGE Thermo-Electric Cosimulation meshing(?) Issue › Reply To: CHARGE Thermo-Electric Cosimulation meshing(?) Issue
April 9, 2024 at 3:08 am
Thanks for the tips! It turns out the issue was not with the mesh: the bug was that the materials only had defined electrical properties (addmaterialproperties("CT",...)) and not thermal ones (addmaterialproperties("HT",)) (this is because CHARGE doesn’t specify materials by default and I had written a script to add them). The HEAT (co-)solver was silently crashing with no error reporting. I discovered this error by setting up a discrete HEAT solver and trying to run it.
