Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Moving heat flux issue in ANSYS transient thermal › Reply To: Moving heat flux issue in ANSYS transient thermal
April 9, 2024 at 1:00 am
wei
Thanks for your reply.
May I ask is there a rule of thumb for setting the time step in modeling? For example, in a CFD world, there is Courant Number to follow?
Also, I am not sure if it is still the time step problem which led to some negative temperature in the first couple dozen steps.
Thank you.
