Ansys Learning Forum Forums Discuss Simulation General Mechanical Prevent penetration of an object to other object using contact Reply To: Prevent penetration of an object to other object using contact
kyungha.lee
Hi, Stella.
Thank you again for all the useful links and the information.
What I want to see is the effects of having a gap between the cube and the beam when they have slighlty different diameters.
Will it be possible to see this effect when I model the cube and the beam with the same diameter?
I have tried all the above solutions but when I auto-scaled, I could still see the penetration. The accleration I have applied is low so in real life, the model will not deform like that but I would like to model the simulation as closest to the real world as possible.
Kind regards
Kyung Ha Lee
