Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Need help with: Error: error: wta[1](string) Error Object: () › Reply To: Need help with: Error: error: wta[1](string) Error Object: ()
I'm not permitted to download any files. Looking at the above, check the layering part to ensure there are no zones to the sides, and if there are that they're not connected. I think the non-deforming parts should be moving, probably with rigid body. Won't you just need a mass sink on the reacting side, and then mesh motion is linked to that? Ie there is no mass source into the solid.
