Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How to defined Pre-Exponential Factor as function in Fluent? › Reply To: How to defined Pre-Exponential Factor as function in Fluent?
April 8, 2024 at 2:12 pm
Double check the Fluent theory to make sure it's not doing what you need, but otherwise you may find DEFINE_VR_RATE or DEFINE_NET_REACTION_RATE to be of use. There will be examples using both macros in the UDF manual.Â
