Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Frequency Statistics Analysis – Ansys AQWA › Reply To: Frequency Statistics Analysis – Ansys AQWA
Shuangxing Du
To add in the Aqwa debug option, you could use External Operation before Solving (See Aqwa User's Manual, Section 5.9.1. Specifying External Pre- or Post-Solve Operations). By setting this function as Run a Python Script, and in your Python script, you could add in the following lighlighted items into the input data file in (your project)\dp0\AQW-1\AQW\AQ\Analysis\Frequency.dat
