Ansys Learning Forum Forums Discuss Simulation Fluids Trouble with population balance for bubble column simulation Reply To: Trouble with population balance for bubble column simulation
Please check the mesh aspect ratio, and change in cell size around the inlets. I suspect the cells are OK for single phase, but you need a fine mesh with very low aspect ratio and growth rate for most multiphase applications.
If the population balance allows bubbles to grow in regions of low shear, how does that plot tie up with the bubble size? How is the bulk flow behaving?Â
