Ansys Learning Forum Forums Discuss Simulation LS Dyna Permanent connection between steel and rigid shells Reply To: Permanent connection between steel and rigid shells
Alex R.
Rigid bodies cannot be included in a constraint-based contact, only tied contacts that are penalty based can be used with rigid bodies.
You could use *CONSTRAINED_EXTRA_NODES_OPTION that will allow you to constrain an edge of a shell (made of metal) to the rigid shell in your model.
Please let me know how it goes.
Thank you,
Alex
