Ansys Learning Forum Forums Discuss Simulation General Mechanical Node Merging mesh from acp shell geometry Reply To: Node Merging mesh from acp shell geometry
Govindan Nagappan
Or you can start wth connected surface geometry. Create the solid mesh on both sides of the shared surface by using the proper orientation in ACP. THis way the mesh is already connected in ACP
