Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Node Merging mesh from acp shell geometry › Reply To: Node Merging mesh from acp shell geometry
April 8, 2024 at 12:32 pm
You will have to start with the two surfaces that touch each other and build the solid mesh from that in ACP. Make sure you have element sets for regions where you want to merge the nodes. Then you can use node merge in Mechanical from the ACP mesh. Or consider using bonded contacts
