Ansys Learning Forum Forums Discuss Simulation LS Dyna Add materials from Workbench Ls-dyan using engineering data Reply To: Add materials from Workbench Ls-dyan using engineering data
Ram Gopisetti
I am not sure what version of ANSYS you are using here, but Johnson cook is supported natively and in the newer version, EOS JWL, GRUNEISEN are supported.
However, for the combination of material model and unsupported EOS, you need to use the command snippets specific to the plates , check the link /forum/forums/topic/ansys-workbench-ls-dyna-material-command-snippet-causing-error/ on procedure
For  Steinberg material model, see material model 011.
Cheers, RamÂ
