Ansys Learning Forum Forums Discuss Simulation Fluids GPU acceleration in CFD analysis Reply To: GPU acceleration in CFD analysis
The gpu offload is only compatible with a few models so you may find it's not giving much of a speed up. Depending on cell count and models more cpu may give a good speed up, but that also assumes the hardware can handle the message passing between the cores.
