Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Spaceclaim API C# – Generate Midsurface › Reply To: Spaceclaim API C# – Generate Midsurface
April 8, 2024 at 10:58 am
Hello Udeep,Â
This is only exposed in the scripting API. If you would like this in C#, you will have to rework the logic of this. This might be possible to record using Script recorder in SpaceClaim as shown below:
options = MidsurfaceOptions()
options.Group = False
command = Midsurface(options)
command.AddMatchingFacePairs(FaceSelection.Create(Face1, Face2))
result = command.Execute()
or based on an ionterval
command.AddFacePairsByRange(Body1, MM(0.91), MM(1.6)
Regards,Â
DevendraÂ
