Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Change default exported variables in Fluent › Reply To: Change default exported variables in Fluent
You can't remove data from a Fluent data file as that's needed for a restart, you can add data fields. You can alter what goes into cdat files.
Report Definitions are computed on whatever they're set on: that can be points, lines, surfaces, registers or volumes.
