Ansys Learning Forum Forums Discuss Simulation Fluids Import Mesh Error Reply To: Import Mesh Error
nilay.pedram
To import the mesh file correctly into Fluent in .cgns format, you need to first import the mesh using the mesh only option and set up boundary conditions. Then select appropriate model and read the data using the data only option. Hope this solves the issue. Thanks!
