Ansys Learning Forum Forums Discuss Simulation Fluids Change default exported variables in Fluent Reply To: Change default exported variables in Fluent
SRP
To manually select variables such as Total Pressure and Viscosity ratio to be included in the data file of a Fluent simulation, you can use Report Definitions. Report Definitions allow you to specify a certain quantity or set of values to be computed at the end of a solver timestep or iteration.
