Ansys Learning Forum › Forums › Discuss Simulation › Fluids › material properties input › Reply To: material properties input
April 7, 2024 at 5:52 pm
Hello sir
This is the point cuz the material density value is different between the solid and the liquid state as indicated in the table above.
In fluent i cant use piecewise linear and boussinesq in the same time.
I'm so confused what to do when i use boussinesq option what value of the density should i input.
Thank you for your feedback.
I have another question or problem as well if you don't mind.
My MCP melt inside an annular cylindre and when the process of melting finnished the the temperature increase instantly which is desagree whith the experimental work.
N.B here is the the cp i used:
and this is my plot:
